It is currently Thu Aug 14, 2025 11:57 pm
PostPosted: Sat Jan 31, 2015 12:01 am
First name: Charlton
Last Name: Wang
Does anyone have any insight into whether grain orientation for solid linings matter? Can I, for example, take a flatsawn piece of maple, resaw it into 2.2m slats, bend them on the side bender, laminate them and then cut them into strips to glue to my ribs or would I be better off ripping little quartersawn strips and then laminating those instead? Intuition tells me it doesn't really matter since the strips are so narrow and thin.
Thanks!
Charlton
PostPosted: Sat Jan 31, 2015 12:45 am
I don't think it matters much, but it may, depending on the choice of wood.
If I choose Mahogany, I like the strips flat-sawn for ease of bending.
A hardwood like Maple probably doesn't matter, the grain orientation, but I try to choose by which way I think it will be easier to bend.
PostPosted: Sat Jan 31, 2015 4:35 am
The flat sawn may have a tendency to cup more, across it's width. Quartered stuff cups a little as well and I always find that I have to scrape certain areas on the back of the lining to get a good close fit to the sides. I use a bending iron though, so you may well have a different experience with the machine.
PostPosted: Sat Jan 31, 2015 6:48 am
I would suggest that vertical grain material would be the better choice, its not a big deal but having similar shrink and expansion rates is a good idea -- here's the inside of an R Taylor looks like 1/4 sawn to me.
http://www.rtaylorguitars.com/Woods-Details-01.aspx
Just want to add an edit here -- the linings in the R Taylor are solid hardwood which I believe we are discussing. As opposed to laminated linings.
Ken Cierp
PostPosted: Sat Jan 31, 2015 7:42 am
State: Tennessee
Grain orientation on laminated linings is inconsequential good joinery and how they fit your sides is what matters.
PostPosted: Sat Jan 31, 2015 8:02 am
"good joinery and how they fit your sides is what matters."
I think even that is less important than what some people believe. Some guitars with sloppily fitted tentalones still sound fine and hold together well enough. Tight fitting, well made linings are somewhat better and much prettier though.
These users thanked the author Clay S. for the post: Bryan Bear (Sat Jan 31, 2015 10:28 am)
PostPosted: Sat Jan 31, 2015 11:53 am
First name: Ringo
It matters only as an intellectual exercise... certainly not as a practical matter.
PostPosted: Sat Jan 31, 2015 1:36 pm
State: Tennessee
So what exactly are you saying? Crappy, gappy glue lines, maybe some twist? Since laminated linings are kind of stiff offset them so they distort your sides? duh
PostPosted: Sat Jan 31, 2015 2:45 pm
I am at a loss on this one too. Not knowing what the "some people" view of excellence happens to be. It appears that mediocrity (good enough) is given a pass on craftsmanship. True I've seen some pretty crappy looking guitars with all sorts of miscues, that to my ears sound pretty good -- question is why would one lower the bar on this particular construction phase?
Ken Cierp
PostPosted: Sat Jan 31, 2015 3:14 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I made these linings from dyed, flat sawn poplar. No springback, and very stiff.
Alex
PostPosted: Sat Jan 31, 2015 3:26 pm
If it were me, I'd be using wood oriented the same as the sides, as if you'd taken a side and cut the lining strips from it.
One thing I'd like to ask you folks into solid linings (or laminated)...
How do you get it to match the sphere of the back, bending the direction along the length? Standard kerfed linings are bad enough as far as wanting to gap where the waist bends. How do you get around that?
PostPosted: Sat Jan 31, 2015 3:45 pm
State: Tennessee
I've done two and I went with 3/4 width (.240 X .750) on the lining, glued to a line 5/8's depth on the sides and used a small block plane to hit my radius with minimal sanding with the radius dishes. It really stiffens things up. Of course the grain is paralell with the sides , flat sawn versus quarter sawn for a 3 ply lamination is not an issue.
These users thanked the author Clinchriver for the post: Alex Kleon (Sat Jan 31, 2015 3:49 pm)
PostPosted: Sat Jan 31, 2015 6:38 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
My experience with laminated solid linings (I've used basswood, mahogany and poplar over the last 40 years) is that grain orientation does not matter. I've never had a problem making them conform to the compound curves created by the radius of the back or top either.
These users thanked the author David Wren for the post: Alex Kleon (Sat Jan 31, 2015 10:42 pm)
PostPosted: Sat Jan 31, 2015 11:13 pm
Do you add the lams one by one, or add to the rims as a composite?
PostPosted: Sat Jan 31, 2015 11:53 pm
"So what exactly are you saying? Crappy, gappy glue lines, maybe some twist? "
"Not knowing what the "some people" view of excellence happens to be. It appears that mediocrity (good enough) is given a pass on craftsmanship."
Yes , exactly... crappy, gappy, linings (within reason) will work. Well fitted linings certainly look better and are the mark of good craftsmanship.
Robert Lundberg espoused the "good enough" workmanship ethic. I would never suggest he did sloppy work. As one's skill set improves what was "good enough" , no longer is, and the bar is raised.
PostPosted: Sun Feb 01, 2015 12:45 am
I use a few strategies...
2 or 3 part laminations, glued into the sides one at a time, so the twist is "averaged".
I cut one kerf in the lining at the waist, where the arch mostly occurs.
The linings are wider than needed, at the neck block they ride higher and are trimmed off over the sides.
PostPosted: Sun Feb 01, 2015 1:20 am
Thanks!
PostPosted: Sun Feb 01, 2015 3:51 am
First name: Trevor
Last Name: Gore
City: Sydney
It depends on the wood and the glue. Apply a water based glue to just one side a flat sawn slat as part of a lamination and there's a fairly good chance it will cup, which then has to be clamped flat, but that only happens on the piece exposed on the inside of the guitar. The other slats see glue both sides. Reverse kerf linings can occasionally behave in the same way, cupping as they are being glued, which makes them a PITA to clamp flat. The amount of pain is proportional to the depth of your linings.
http://www.goreguitars.com.au
PostPosted: Sun Feb 01, 2015 4:10 am
Yes, if you look at Lundbergs work it's quite obviously a bit more than 'good enough'. I tend to think he wasn't really referring to bad joinery but things like the 'billiard ball finish', scraped tops/ribs (rather than sanded), finished knife cuts rather than things being over sanded ect. I think he was trying to produce Lutes in the tradition of Lute building - made by very highly skilled craftsmen but without being overly fussy. That's my take on it.
PostPosted: Sun Feb 01, 2015 8:54 am
Hi Michael,
I agree with your above statement entirely, especially about the part "without being overly fussy" , and that was the point I was trying to make. Poor workmanship is poor workmanship and I'm not advocating that. However, linings are an area where less than perfect execution probably won't hurt the instrument from a functional standpoint. As an amateur I strive to build the best instrument I can within my skill set, but I don't sweat less than perfect work in places that don't matter. As my skills improve, so does the workmanship. Not being a "Master Luthier" isn't going to keep me from building instruments.
Users browsing this forum: J De Rocher, TimAllen and 14 guests
